Tucson 2006 horn does not work
Old 06-07-2011 | 11:25 AM
hfarsi's Avatar
Default Tucson 2006 horn does not work
My horn does not work - never worked properly - sometimes when i stopped worked but not when I am driving !
Now is completely dead - How can I check it - Where is the fuese for it - i liek to check that first . It seems my alarm also does not work .
Old 06-07-2011 | 02:24 PM
If it worked intermittently the problem is probably not the fuses as that is an all or nothing situation. However, the relay is located in the fuse box in the passenger compartment. Next check the horns themselves. The are located behind the front bumper and belowe the headlights. You have to remove the headlights to access them.
Old 06-08-2011 | 03:09 AM
hfarsi's Avatar
Thanks for you assistance
I tried to get the rely out - but could not -
Here is what happens however - the red panic button on key chain makes the horn work - however pushing the horn on steering wheel does not . rarely works ( 1 out of 80 times lets say ! ) - what should I look for ? Please assist .
Old 06-08-2011 | 07:15 PM
Just use your DVOM and test for source voltage at horn connector,, then back track from there.
BTW,, what are we playing with ??
5yr/60,000 on horn if applicable in your case.
Old 06-09-2011 | 11:27 AM
The horn for the alarm is different than the 2 horns for the steering wheel.
So having the alarm horn work means nothing about the steering wheel horns.
Old 07-13-2012 | 02:05 PM
clinton's Avatar
Any findings on this? My horn is dead too
Old 07-13-2012 | 07:54 PM
Check the relay and fuse.
Philip James Bohlken
09-29-2012 10:50 AM
lamb667
12-07-2010 06:54 PM
rabt
05-04-2009 03:06 PM
Mika
05-28-2008 10:46 PM
cmkerns
02-01-2006 08:38 PM
