Hyundai Veracruz This crossover combines the functionality of a minivan in a sleek exterior with luxury qualities.
armrest removal
Old 02-21-2013 | 10:37 AM
lunyty1's Avatar
Default armrest removal
i bought a 08 veracruz and love it except for the broken latch on the front console armrest rattling,,i ordered and received the new latch from hyundai,but now need to install it,,,,does anybody know exactly how to take this armrest apart for latch removal ?? any help much appreciated
Old 02-21-2013 | 12:09 PM
COMPONENTS
ARMREST REPLACEMENT
1.Remove the storage box (A).
2.Remove the rear console cover (A).
3.After loosening the armrest mounting screws, remove the armrest (A).
4.Installation is the reverse of removal.
Old 06-23-2013 | 02:02 PM
Snownsky's Avatar
The latch on part # 8 recently broke on our '07 'Cruz. How did you go about disassembling the cover & replacing the latch?
Thanks!
Old 12-06-2013 | 03:37 PM
Charlie Gorney's Avatar
Default So how did you end up fixing?
I have an 08 VC and have the exact same problem... I have the new part but now I need to disassemble the armrest to replace just the latch. How did you end up doing it? Thanks.
Old 02-01-2014 | 06:11 PM
scjetson's Avatar
I changed mine out and if I remember right I took a butter knife along the edge of the top padded console to unlock the tabs that hold the top on and then you can get right at the screws that hold the latch.
Old 08-24-2015 | 02:04 PM
Tak's Avatar
Tak
I just completed this job on my wife's Veracruz. To remove the armrest you will need to:
1. Remove lower console tray. To do this first remove rubber piece in bottom of tray, then pry out plastic cooling vent piece. After you have removed rubber and plastic pieces, remove two phillips screws at bottom of tray. You now can carefully pry the tray out.
2. Remove rear center console control panel. To do this first you will need to remove the two phillips screws located at the top right and left of control panel. Look at the rear of where you just removed the lower console tray. Once these are removed you can carefully pry off the rear panel. Be carefull of the 3 wire connectors behind the panel. There are 3 tabs with clips pere side. Now remove 2 10mm bolts and 2 nuts holding the armrest assembly. Install in reverse order.
Old 06-29-2016 | 12:32 PM
Torquey's Avatar
Default Where to buy
Hi
I have a 2007 VC, where can I buy those latches for both front and rear other than the dealership? Or if at a dealership, where did you guys get them?
Thanks
cumitbas
01-07-2014 01:41 PM
decalsRus
04-17-2012 09:44 PM
LoveMyXG
03-21-2011 09:50 AM
bigorange
06-03-2009 05:17 PM
hella356
10-14-2005 02:18 PM
Quick Reply: armrest removal
