Hyundai Veracruz This crossover combines the functionality of a minivan in a sleek exterior with luxury qualities.
Veracruz Dash
Old 03-23-2009 | 02:08 PM
Stephen's Avatar
Default Veracruz Dash
Does any one know, If I pop the centre Dash to get to the back of the head unit will it pop back on again or is it going to be all broken clips and major hastle?
Thanks,
Stephen.
Old 03-23-2009 | 05:56 PM
CENTER FACIA PANEL REPLACEMENT
NOTE:
- When prying with a flat-up screwdriver, wrap it with protective tape, and apply protective tape around the related parts, to prevent damage.
- Put on gloves to protect your hands.
1. Disconnect the negative (-) battery terminal.
2. Remove the air vent panel(A).
3. Remove the connectors (Hazard lamp connector, incar temperature sensor connector).
4. Remove the center facia panel (A) after loosening the screws(6EA).
5. Remove the mounting screws(6EA) then remove the audio unit.
6. Installation is the reverse of removal.
Old 03-24-2009 | 09:37 AM
Stephen's Avatar
Thumbs up
WOW. Thank you that will be very helpfull.
Stephen
mkaresh
01-04-2015 12:04 PM
hynvuser
12-20-2010 09:11 AM
veracruzfans
03-23-2009 02:00 PM
jeff812
12-18-2008 06:52 AM
acdii
03-23-2008 11:13 PM
Quick Reply: Veracruz Dash
