Veracruz door lock issues
I have a 2007 Veracruz Limited with a door lock issue. Currently the rear hatch exterior opening switch above the license plate, as well as the interior push button will not open the hatch unless the vehicle ignition is in the "on" position. The key fob will lock and unlock the hatch and all doors remotely with no problems. The interior door lock switches on the door panels do work. However, anytime the front passenger door is open the door lock solenoids in ALL 4 doors click continuously. Once the front passenger door is closed the solenoids stop clicking. I am looking for help in fixing the issue. Any ideas on what could be causing the issue and what I can do to fix it would be helpful. Thank you. DR
