2005 XG350 Rattle in Rear Deck Near Speakers
Old 06-22-2006 | 09:58 PM
emtbch's Avatar
Default 2005 XG350 Rattle in Rear Deck Near Speakers
I love my 350 - it is the nicest car i've ever owned. However, since buyinmg it, I"ve had a rattle in teh back speaker deck where teh speakers come through the deck. It happens while driving over even slightly bumpy pavement. Has anyone experienced this? Also, soes anyone have instructions on how to remove teh speaker covers of the deck itself? Thanks
Old 06-30-2006 | 11:12 AM
Real1's Avatar
Default RE: 2005 XG350 Rattle in Rear Deck Near Speakers
I have just purchased one and I have a rattle in the rear, I have looked at spare tire and under the car I cant find it either let me know what you come up with
ORIGINAL: emtbch
Old 07-02-2006 | 07:58 PM
emtbch's Avatar
Real 1 - OK - Ifigured it out. The rattle formy car was the rear brake light assembly which is mounted on the rear deack. You know, the breake light in the middle of the rear window. You have to remove the whoel assembly. This is done by opening the trunk and looking for two small bolts protruding from teh rear deck. Unscrew these and go bak into the seating area and remove the light assembly. You will have to unhook the light form teh electrical power.
Inside the assembly there ate five small screws - remove these. the part that ratteles in teh read lens. As you will see, iti si not fixed in there firmly. I glued some thin pieces of rubber to teh framing are and then slid the lens back into the groove and glued it, too. It woroked like a charm.
Word of caution... I used crazy glue. If you've seen any crime shows on TV, you may know they use stuff to identify finger prints by heating it in a closed area. When, what I foudn id that when teh brake lights came on, it heated the glue which vaporized and stuck to teh rear windshield. Perhaps you might use a different gleu and see how it works.
Good luck.
Vavso
11-10-2009 12:32 AM
taxlienusa
08-26-2009 01:07 AM
parra702
01-29-2009 10:59 AM
Estoril73
01-27-2009 03:06 PM
pentecostjw
12-30-2005 02:42 PM
Quick Reply: 2005 XG350 Rattle in Rear Deck Near Speakers
