2005 XG350L a/c compressor engage
Typical system pressure sitting after equalization will be approx 100psi.
Likely need to add a can of R-134 to bring sytem pressure up to flip the triple switch and make A/C run.
5yr system with 3-6 month idle time on A/C is good for system to seep out past compressor seal a little each year..
After repair, make it a point to run A/C all the time, and adjust temp as needed.
