Check Engine Light
Old 09-17-2006 | 03:55 PM
NoLimit4's Avatar
Default Check Engine Light
I have a XG350L that has 40k miles and will be 2 years old this November. I've been very pleased until a weird problem surfaced. One day last week the check engine light came on coming home from work. I followed manual instructions for the check engine "Malfunction Indicator Light" which seems to deal with the exhaust gas related component. My dealer had the car for the first fix attempt and reported a "CODE PO446/PO441 OPEN CIRCUIT" problem. Their solution was to replace the "purge valve".
I picked up the car, the check engine light was off and everything seemed ok. The very next day I drove my 52 miles one way to work without incident. However, on the way home at night only 5 miles into the drive, the light came back on. Back to the dealer the next morning for them to attempt solution #2. The reported problem this time was "EVAP VENT CONTROL - MALFUNCTION CODE PO446." The fix was to replace the fuel tank pressure sensor. It was Friday night when I picked up the car and thought everything was good and the check engine light was off.
The very next morning I drove 2 miles to the gym and the light came back on. My dealer service shop is only open until 1 PM on Saturdays. When I went there they said they could not look at the car again until Monday morning.
I'm left scratching my head on this one. The other check engine light threads in this forum had different problem codes. Could it be that I just had a bad tank of gas? If yes, I have a 1/4 tank left. Should I burn that off first and then refill? If I refill, I would still need the dealer to clear the code. Correct?
Again, I'm scratching my head and running out of patience. I'm not pleased over the prospect of adjusting my vehicles so I can drop the XG-350L off and then only find out that the problem resurfaced again the next day.
Any ideas? Thanks in advance!!
Rob
Old 09-27-2006 | 07:47 PM
Doohickie's Avatar
Default RE: Check Engine Light
I've had similar problems with my Elantra. I had different codes, but they pointed to evap system problems too. I first had the problem in March of this year, then it recurred in August. I think the first time they alleviated the symptom and I'm hoping this time they have eliminated the cause (keeping my fingers crossed).
My best advice is to keep taking it back to the dealer until they fix it. Guilt them into giving you a loaner if you can; tell them considering all the times THEY have misdiagnosed the problem, it is the only way you'll give them top marks on the satisfaction survey (if you get one).
Encourage them to contact Hyundai TechLine if they have not already done so. If you're really frustrated, email me; I may be able to direct you to someone who can help (a former HyundaiUSA employee who has a lot of knowledge about the cars).
Old 10-01-2006 | 02:06 AM
NoLimit4's Avatar
This was finally fixed by the dealer on the third try. I added one additional fact on problem info when I dropped the car off. For the last two gas refills, I was unable to completely fill the tank. I suspected that maybe it was the gas station's pump problem. The warrenty repair report stated - cause: CCV Air Filter PO446 Vent Controll. correction: Replace ETHE CCV Air Filter. The service manager indidcated that the part was a filter cannister in the gas tank. The problem was solved. Thank you Doohickie for your posting.
jordanwake
02-06-2011 09:13 AM
duude1
02-03-2006 07:04 PM
mlowe
12-23-2005 03:48 PM
Lydia1
11-01-2005 10:45 PM
tomholl
07-28-2005 01:53 AM
