HLA Knocking???
Old 05-09-2012 | 09:11 PM
MKDoWork's Avatar
Arrow HLA Knocking???
I have a XG 350 that started knocking a few days after an oil change from a local Valvoline shop. It sounds like it is coming from the top end on the left bank (the side under the intake manifold). After doing some reading I thought it was a bad HLA. I have checked all of them and they all seem to be good. Any ideas?
Also I noticed all og the HLA's have a pin hole in the side of them. Does anyone know which way it is supose to face?
Old 05-10-2012 | 09:07 AM
What oil filter did they install? If it wasn't an OEM Hyundai filter that could be your problem. Many cheap aftermarket filters are too restrictive and could starve your engine for oil.
Read: https://www.hyundaiforum.com/forum/a...-05-20-002-pdf
Old 05-11-2012 | 01:09 PM
MKDoWork's Avatar
It is an aftermarket filter. I also found out the tech used 10w40 oil. I asked the local dealer and he said to use 5w20. We live in south Florida. Would the combination of these 2 being wrong cause knocking and the HLAs not to operate correctly?
Old 05-11-2012 | 02:17 PM
That oil is way to thick. Yes, the combination of the 2 would cause that problem. Use a Hyundai filter and a 5w20 oil and the knocking should go away.
rm125chris
03-15-2010 11:18 AM
mopar92
08-10-2009 08:37 PM
Chas2001
11-26-2007 12:23 AM
jducasse
06-19-2007 12:14 PM
jducasse
06-19-2007 10:38 AM
