How to set timing marks 2001 xg300
Old 05-22-2011 | 08:41 AM
howdydowdy's Avatar
Default How to set timing marks 2001 xg300
When I allign the timing marks and try to put tensioner on timing belt 2 of the gears move. Do they have to be alligned exactly with marks.
Old 05-22-2011 | 04:39 PM
Umm,,,, yes, the marks need to align with the reference marks.. start getting teeth off, engine may ding valves, be out of time that engine wont run proper..
4 cam XG is not for the beginner... having fun with the Bank 1 exhaust cam are we ??
Paint mark the old belt to gears --
Transpose marks from old belt to the new belt and reinstall,, can't miss --
Use shop rag to hold belt to crank cog and work way around in counterclowise manner --
Attached Thumbnails How to set timing marks 2001 xg300-pict1089.jpg   How to set timing marks 2001 xg300-pict1091.jpg   How to set timing marks 2001 xg300-pict1092.jpg   How to set timing marks 2001 xg300-pict1094.jpg   How to set timing marks 2001 xg300-pict1096.jpg
Old 05-23-2011 | 10:42 AM
howdydowdy's Avatar
Default Timing
Engine went out of time because crank sproket came off so I cannot mark old belt. I finnally got the marks on by useing little paper clips you squeeze to open. I thought I had all lines on the 5 sprockets lined up. Top dead center on crank and the white dots to the tabs which meant the blue marks on each sprocket lined up. When I put back together engine runs but when you let off gas pedal it stalls. Is there any adjust to move the timing, like with a distributor or something.
xjdubber
03-02-2018 01:30 PM
tsnitro
03-25-2013 03:26 PM
Tim06
09-30-2011 01:59 AM
BKelly42
06-03-2009 09:04 PM
travsher2008
05-26-2008 07:34 PM
Quick Reply: How to set timing marks 2001 xg300
