Location of power wire that feeds backup lights
Old 10-17-2012 | 07:08 PM
lPenn's Avatar
Default Location of power wire that feeds backup lights
I have just installed a 2din unit from chinavasion that has cd, dcd, gps, OBII, Bluetooth, and more in my 2002 XG350L. These 2din units fit almost as they were made for the car. Too make the install simple use the mounting bracket from original radio. Then remove the face plate from the original radio and using a router and Formica bit route out the faceplate to fit over the new unit. The results look as if installed by Hyundai.
The backup camera power feed wire to the backup lights needs to be pickup under the dash. Would someone know where and color of wire is located? I assume it is behind cover driver side at floor below dash. They are several wire connectors at that location.
Thank you,
fredmr
08-16-2021 11:00 AM
happygame303
11-05-2013 08:09 AM
hifiman5
08-10-2012 07:48 PM
funrunner
11-19-2010 10:42 PM
mjluddenjr
04-14-2009 01:02 PM
