Proper Tire Pressure
What should the tire pressure be on my '05 XG350? The tires are Bridgestone Potenza G009 P205/60R16 and say a max of 35psi. When I have them up that high you can hear every little road bump echo through them. I read the door and it said 33psi front and 30psi rear. When I set them his way the front tires always look flat. What do you think? Thanks,Scott
Go by the sticker on the door. Modern radial tires "look flat" because the sidewalls bulge out at the bottom. It's normal.
Car Talk
How Radial Tires Work | eHow.com
Car Talk
