2002 haundia elantra radio etc. not working
Can anyone out there give me any insight on a problem...The fuse F25 inside the car blows.. Right now I have no: Radio/Interior lights/Gas gauge/Eng. temp/Door locks...I did notice when the car is on the door locks will jump to the opposit position if attemted to lock or unlock??
RE: 2002 haundia elantra radio etc. not working
It sounds like you have a short. Hyundai issued a TSB about corrossion of the connector for the door. Even if you're out of warranty, ask a dealer if there is anything they will do for free to address the issue. Barring that, you may want to try to do something yourself to fix it. The TSB involved is
03-90-009, 2001-03 Elantra Corrosion in the Front Door Wiring Connector
DESCRIPTION:[/align]
A water leak between the front outer panel and cowl panels may result in corrosion of the front door wiring connector pins if the vehicle is operated in areas where road salt is used. The corrosion may affect the operation of the electrical circuits in the door, such as the speakers, power windows, etc.[/align]
To correct this condition, reseal the seams and inspect the door wiring connectors for corrosion. If necessary, replace the door wiring connector and the door wiring by following the service procedures described in this TSB.[/align][/align]
anita
04-27-2009 07:18 AM
