Hyundai Accent 2006 GLS 1.6L DOHC TIMING BELT QUESTION
Old 01-02-2013 | 06:19 PM
sanscwbys1's Avatar
Cool Hyundai Accent 2006 GLS 1.6L DOHC TIMING BELT QUESTION
My daughter's car timing belt slipped. After inspecting the belt it was missing teeth around the belt. After replacing the timing belt, I lined up timing marks, went to start the car with no luck. The car turns over, gets gas and and spark. My question is this: Is it possible to have the timing 180 degrees out? If so, how do I get the timing correct? Would this cause no compression? I did not have a compression gage to check compression. Placing my finger around the number 1 cylinder through the spark plug I felt no air pressure. Would this be the cause of my car not starting? Stumped and need help ASAP!!
Old 01-02-2013 | 07:05 PM
If the timing belt slipped while running, the valves probably hit the pistons and bent. That's probably why you have no compression.
texaspete
11-01-2015 05:54 AM
Reager
07-01-2013 11:32 PM
mevin69
11-06-2011 04:14 AM
helimech
12-13-2006 09:58 PM
slimone
07-18-2006 02:48 AM
Quick Reply: Hyundai Accent 2006 GLS 1.6L DOHC TIMING BELT QUESTION
