hyundai excel headlight assembly
Does anyone know how to get the headlight assembly out of an excel.
there are two 10mm top bolts and a screw that are out but it seems to be attached behind the indicator assembly.
I am at the point of using a percussive persuider.
do i have to take the bumper or the guard inner off?
thanks in advance
thanks in advance
HEAD LAMPS
Removal and Installation
1. Open the hood and disconnect the battery negative cable.
2. Remove the radiator grille.
3. Remove the front position lamp.
4. Remove the headlamp mounting bolts. Disconnect the wiring connector.
5. Remove the headlamp assembly.
6. Installation is reverse order of the removal.
1990-1994:
HEADLAMP
Removal and installation
1. Remove the radiator grille.
2. Remove the front turn signal lamp.
3. Remove the headlamp connector.
4. Remove the headlamp assembly with transverse filler.
5. Separate the head lamp from transverse filler.
6. Installation is the reverse order of removal procedure.
HEAD LAMPS
1990-1994:
HEADLAMP
thank you for your help.
12 hour shifts mean i don't get to the computer for days at a time
i must apologise for not putting in the year its a 1999
in the end the indicator assembly is held by 2 locator pins and a push pin for want of a better word.
It's just a pull and pray and out it comes
once again thanks for your help
There is no 1999 Excel. The first generation Excel was made from 1986-1989 and the second generation was made from 1990-1994 (with the exception of the Philippines where it was made until 1998).
Are you sure you have an Excel and not an Elantra or an Accent?
this is an australian vehicle if that makes any difference
1999, HYUNDAI EXCEL, Adelaide, Dealer Used, $49,990 at carsguide.com.au
this is the same as the car that is parked in my drive way
don't look too hard at the price the seller obviously does not proofread
thanks
thx1971
04-13-2009 09:15 AM
