98 or below Tib engine
RE: 98 or below Tib engine
condition is ok it just needs to be cleaned up the block that is. i had sucked some water into the manifold and one of the cyclinders froze up. after taking it apart i saw everything was fine just the one piston had a little resistance in it when pulling it out. i have the (pistons minus new rings), intake, t.b., coil pack, rods, bearings, pulleys, head (dissasembled and cleaned), sensors, injectors, rail, etc
it does need thermostat housing, trans., rings, gaskets, whatever bearings you might want to replace , etc.
if you are really interested we can talk over to the phone so we make sure we get everything squared away.
SDMJL
10-20-2006 12:53 AM
