Suspension Talk about your suspension within.
2002 Elantra Suspension Question
Old 07-21-2008 | 11:40 AM
excaliboar's Avatar
Default 2002 Elantra Suspension Question
My 02 Elantra, 130k, is making a thumping noise that is associated w/ speed and seems to be coming from the driver's side rear. Just had tires replaced, and they had an uneven wear pattern around the circumference of the tire. Tire shop did an alignment, but said I may have a strut issue. Any ideas of other possible problems? How would I go about replacing struts?
Old 07-21-2008 | 11:51 AM
Default RE: 2002 Elantra Suspension Question
You need to remove the strut and spring from the car. Have the spring compressed and removed then add the spring to the new strut and install the new strut/spring. Check http://www.hmaservice.com for the procedure.
molayne17
05-18-2021 11:01 PM
DSG
11-03-2018 03:08 AM
roanoke10
06-22-2013 10:51 AM
excaliboar
07-18-2008 11:01 AM
geoffcantley12
04-05-2008 04:47 PM
