Tires What skins are you rollin' around on? Discuss wrapping your rims in here.
Wheel size for 2010 Hyundai Elantra
Old 02-28-2013 | 11:17 PM
icecoldiceman's Avatar
Default Wheel size for 2010 Hyundai Elantra
Hi,
Got a stock steel rim 15" and planning to buy an alloy one to replace this steel rim and use the same tire size 19565R15.
What are the acceptable offset, wheel width and center bore that I should be looking at aftermarket wheels? Any other parameter I should consider?
Thanks!
Old 03-03-2013 | 10:50 PM
BigDogg's Avatar
Thumbs up Aftermarket Wheels
Most wheel/tire stores have the proper size and offset wheels to fit your '10 Elantra. All you have to do is tell them what kind of car it is and what year and they can log in the info and all the proper wheels that will fit correctly will pop up. Pep Boys have a good selection at a great price. Upgraded the factory alloy 16's with an aftermarket 17's alloy with factory size Dunlops. Fits perfect.
Old 03-04-2013 | 05:01 PM
Personally, I think Pep-Boys are good for little things like oil and bulbs but I wouldn't buy wheels there. I'd suggest TireRack.com or DiscountTires.com
molayne17
05-13-2021 09:30 PM
mattoak
01-09-2015 01:38 AM
gd6noob
10-14-2011 08:28 AM
SHOZ
12-31-2009 02:59 PM
06sonata92840
02-02-2009 09:06 AM
Quick Reply: Wheel size for 2010 Hyundai Elantra
